Alignment/Ball joint questions
So I have a two part question. First part:
I took my car to Firestone because I have a life time alignment. I started feeling weird vibrations in the steering wheel and a faint noise whenever I would be A.) Driving about 40mph and B.) Turn the wheel in any way towards the right (slight turn or big turn). I had a hunch it was a ball joint issue, and I assumed as a part of aligning the car, Firestone would check ball joints. I was hoping for a call saying "We can't align the car because your ball joints are bad." Didn't happen.
I have attached a picture of a paper they gave me. It reads "current measurements" and at the bottom recommends adjusting my rear toe and caster. So I assume these measurements are what the car was like before I came in, but does anyone know how to tell if they did anything?
Second question: What are typical symptoms of a bad ball joint? I installed the rennbay track ball joint kit 2-3 years ago ('09 or '10). After running on Talladega this summer, the car started having the weird vibration and noise turning right. I assume it's the ball joint, because I ran into slower traffic on the 33 degree banking (almost vertical) and had to fight to keep the car from sliding off the turns.
Your alignment is off in the rear. I doubt the folks at the local Firestone will want to touch the rear setup on a 944. Take it to a Porsche type repair shop. You should also check your front bearings for play and adjust as needed.
