Hatch glass delaminating slightly- can I just squirt some sealant in there?
Hey Man
As JPK stated, silicon sealants won't work well except temporarily as it has little bond strength to glass. 3M Urethane windshield 'adhesive' in black was what I was referring to; I think I said sealant. As long as it's a urethane base rather than silicon. Again, an off the frame repair is the best but the quick fix will get through a Winter until you can do it right.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
I used Permatex urethane windshield sealant (3M makes a better version of the sealant if you can find it). It's black and viscous enough to press into voids. I taped off the trim and glass edge first so I could smooth out the overflow. I worked both from inside and outside. That hatch never rattled or leaked for the remaining 5 years I had the car. It's not the best way but I have to say it worked very well and is invisible. The key is getting a resilient cushion between the glass and trim piece.
Poor Man's Hatch Seal
thread win. windshield epoxy is probably too hard.
this.
