Kickback on startup
Kickback on startup
I'm allmost out of options and not far from disliking my 951...
Just about one out of four times i start the car i get à kickback to THE starter. System gets à peak at THE ref sensor
Here's what i have done sofar;
Changed wiringloom from dme/klr Changed dme and klr, Changed rotor and sparkplugs, Changed sensors, Changed sensorholder and still no cure..
My second starter just got blown apart because of THE backslash.
We found out that when backfire happens the ref sensor gets à peak current. Only on startup.
Extra ground does not work, help.....
Changed allmost everything i can think of without THE desired normal start.
Before i get rid of THE dme by using a stand alone computer did i miss anything?
Alternator of any influance?
I don't know what MY you have but the 87 models suffered from this until the factory issued a service bulletin. Other models also had these issues if they notched the clutch housing without fitting a shield in place like 88+ models have.
Basically if your clutch housing is notched where the sensors mount and you dont have shields fitted to your sensors you will get:
1. Laboured starting.
2. Backlash when it does start.
Haven't heard of it being as bad as yours but it's worth checking before doing anything else:
Factory Service Bulletin.
I have the updated sensorbracket. My 86.
The current surge is during starting. On the ref sensor. Then the starter gets blocked. That makes the noise. Alternator is old. Did change the old wiring.
Small Business Partner
Have you verified that the reference mark is in the correct position..?
I would also put a timing-light on, and verify that ignition timing isn't overly advanced (indicative of an incorrect reference mark).
I've seen this problem twice and both were found due to an aging connector at the harness to sensor. Suggest you gently probe through the sensors cable covering to get a ground continuity check of the shield. Once you have contact, flex the cable and confirm that the ground is not being lost....Good luck, Bruce
