car gets pulled around a lot by the road
Directional tires are not actually bad, it's just our cars don't get along with them too well. Reasons:
1. Our cars use small wheels (15in/16in) and they tend to exaggerate the tendency of directional wheels to tramline.
2. If we fit bigger wheels (17in/18in) and wider tires, chances are we are running higher camber and castor and this alignment has an exaggerated effect on tramlining with directional tires.
3. Finally, some of our cars ran staggered wheels, Fuchs for example. This also produces an exagerated tramlining effect with directional tires.
Solution:
1. Run asymmetrical non-directional tires. You get good corner grip and stable wet or dry straight ahead stability.
a. Run a square asymmetrical set-up if you still want the ability to rotate your tires R-L F-R.
b.Run a staggered set-up with asymmetrical tires if you just want R-L rotation on each axle.
Hope that helps, GL
