Big wheel fitment for late offset 944/951
Hi!
What the highest front offset for late offset 944s, 951s?
Can your fronts handle 8.5" ET65 (w/235s or 245s)?
So how about ftting 10" ET50 (w/265s or 275s) to the rears?
TIA!
TIA!
Hello Jim,
I’ve not experimented with high offsets to date.
With the wheel in question, I would bet yes with either tire, but can only give reference from a stock ’89 turbo. That wheel would extend 19mm both inward and outward from the turbo CS 8”et65 wheel.
Plug the numbers from your wheel into this page, Wheel Offset Calculator, and measure to be sure.
Just remembered I do use the rear CS wheel, 9” et60, up front with 245/45-16 tires on track. Every car is different clearance wise. These wheels fit fine with a bit more camber on my car.
The rears would be very close and most likely not clear without rolling the quarter lip.
I use an 18x11" et63 rear wheel that just clears the factory rolled lips, ('88 turbo S and '89 turbo quarter wheel arches were stamped flat), at stock camber.
Your wheel is 1mm further out from mine. If the wheels are worth the effort, have at it and post photos too.
Look this thread over for reference… The Official 924/44/68 Wheel Thread.
8.5" wheels in the front are impossible without narrower struts (i.e. adjustable coilovers) or flared fenders. It will hit one, the other, or both.
In the rear a 10" with a 275 will fit, however watch out for the Goodyear Eagle RS DOT 275 track tires. Great tire, but their "275" is closer to a 295.
A 10" wheel with a 275 will fit without rolled fenders, but you need to nail the offset. I don't know what the best offset is. And sometimes it can be different either side of the car - the suspension isn't centered in the chassis.
Take care!
Take care!
Maybe this makes things clearer: http://forums.pelicanparts.com/6890551-post7.html . It can be confusing
BTW, checked out your blog on 928 number one, very cool! With your 928's, I imagine we could hold a reinactment of the 1977 928 Introduction Press Meeting! Wow. A big project on both cars, good luck.
Take care!
Toast is mostly correct. I am using the M030 struts though I’ve changed to the Paragon 2.5 ID Coil-Over Kit, so factory springs could be an issue. I will throw a 9” wheel on and post some pics later today.
Take care!
Take care!
edit: can't see offsets without lifting car or removing a wheel, so i'll have to see what i can do. It is possible i have an 18X8 in the front, not sure yet.
Finally the front 9” CS wheel photos… less than an inch clearance from the M030 strut and 2.5 ID springs. I’d be surprised if the stock turbo or turbo S springs would clear, also would imagine other Listers have tried this too.
Freedom Enthusiast
I've got 295/30 ZR 18 11X45et on the rear of my 90 S2 cab, I had to aggressively roll the fenders to get them to fit. I was told that they would never fit. The pics show that to be incorrect.
I am running 295/30 ZR 18 11X45et on the front So I don't have any info to help answer your question about the fronts. I am using 7mm spacers to allow the wheels to work with the front bearing dust caps. The front bearing dust caps are an issue you need to examine when trying to use different wheels on the front.
AZ Banks, thanks for that information. I just bought some 295 Conti Sport 2's today for my ET54 18x10's, now I don't feel so bad.
