California emissions
Need to get an oxygen sensor for a '88 N/A. They're asking if it has California emissions. It doesn't mention anything on the emissions sticker under the hood. Is that how I would tell?
Option code M027 designated a California version. The sticker is under the carpet in the rear hatch area. Check out this site for more info: http://www.944online.com/cgi-bin/ASI...tioncodes.html
My understanding is that all 944's shipped to the USA had CATs and O2 sensors. My '88 was not a California car, but a Federal car and it passed CA. inspection and smog when I registered it.
Proprietoristicly Refined
All three and 4 wire wire O2 sensors have a heated element.
The black wire is for the signal.
Never solder the wires. Use the Bosch Posilock provided.
If you solder (or poor/bad crimp) the wires, the O2 signal is not accurate to the DME.
Read what the Bosch Sensor Development engineer says:
Part 1
https://rennlist.com/forums/331261-post9.html
and
https://rennlist.com/forums/331265-post13.html
Now, interchange info:
EDIT NOTE --the current Bosch universal is 15735 with the posilock-(the 15725 is out of date)
https://rennlist.com/forums/331271-post19.html
and
https://rennlist.com/forums/331279-post27.html
Or just read it all:
https://rennlist.com/forums/924-931-...placement.html
Now, did you get the Bosch O2 sensor or the knockoff?
GL
John
Part 1
and
and
GL
John
Last edited by John_AZ; 08-01-2012 at 03:42 PM. Reason: Updating current 15735 universal
