Changing the Top Plates
Hey guys I hav been trying to seach this topic, but either I have simply missed it, or I can't find anything on it.
I have a set of LR adjustable camber plates I want to install in place of my stock (extreamly worn out) top plates.
Is it as simple as I think it is? undo the top nutts, jack up the car, the shock assemble comes out, take off the stock top plates, put in the camber plates in their place, lower car, then re-install the nutts?
Is it that simple? Anything special for the LR camber plates? I got a set semi used, and I don't have any paper work that may have come with them, so it's a bit of a trial as I go. Any advice?
You may need a different spring top mount to go with those camber plates, call LR they will steer you right. Fitting is as you stated but you will need an alignment to get everything straight again.
