on the side of road...advice welcome 944 brothers
Yep my '86 na finally let me down guys. It keeps shutting off like I have no throttle. After waiting a minute it fires right back up makes it say another mile then shuts off again. Engine runs but no throttle. Have swapped out ignition relay x with spare same story.
Any advice welcome guys.
Michael
Michael
Can the relay be jumped? Sitting in parking lot letting engine run been running for a couple of minute now no shut off. Maybe I could idle the 60 miles home.....lol
Small Business Partner
http://www.clarks-garage.com/shop-manual/fuel-05.htm
Yep, sounds like a fuel pump...
Anyone have a beer? Oh wait there's a Exxon across the street. No worries hell could be back in Iraq with a broke down Hummer.
I would also loosen the fuel fill cap, just in-case there is a vacuum in the tank making it harder for the fuel pump (I've seen this happen before, though not on a 944/951).
Another possibility is the ignition coil is overheating.
I don't think it could be a bad fuel pump I hear it run when I jump the leads. Replaced fuel filter when I put her on the road. That was 14 months ago but I don't think it could be f@&$ that quick.
No doubt I've been in worse places dude. Hey I have a Heineken and listen to Shawn Hanity on my phone. This too shall pass.
Any other ideas guys?
Keep the jumper in, then drive it - when it dies, see if you still hear the fuel-pump.
1 Post
FPR. is my guess. I was able to get the car home after it began to fail, but after that, it would only start and run for a few seconds and die. Touching the gas made it die to....easy to check..
