on the side of road...advice welcome 944 brothers
Keep the jumper in, then drive it - when it dies, see if you still hear the fuel-pump.
Michael
Small Business Partner
Glad to hear that you found the issue! Sorry to hear about the tow... but heya - at least it is a simple fix.
I have to give you style points for the pulled pork and Guinness
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
BTW...where the heck have you been young man? Any news on a MAF for the NA poor boys out here?
michael
Will take the cool points. Broke out my netbook with ATT air card while I sit here, wwaiting on tow truck, checking out Mississippi's hot trailer park girls coming up to the Shell tonight.
michael
michael
And I've got a couple other things to finish... Hopefully soon!
I thought I would post a couple of follow ups to my adventure Thursday night. Maybe it will help someone else next time.
After I got the word here it could be the DME/Fuel Pump relay I finally started thinking half way straight and checked out Clark's.
http://clarks-garage.com/
Tried the paper clip trick.
and the three way jumper (already had a two way so was just a matter to get a little freaky and do a three way.
For the three way make sure you put them in in this order:
87, 87b then 30.
87, 87b then 30.
So I don't have another fuel pump to try out, and the more research I do it seems like the FPR (fuel pressure regulator) might be the culprit. Ordered one through Autozome should be here today gonna swap it out and see if that makes her happy. If not will order the fuel pump through Ebay. Also, there is a strainer in the fuel tank I paln to flush out, didn't knwo until now there was one.
Here are some pics from Clark's showing the location of FPRs on various models.
michael
when my pump went....the car ran rough but when I would touch the gas pedel it would die.
Fuel pump ran (eg: made noise) but was not pumping enough pressure to operate the fuel system properly.
Picked up the FPR from autozone, $67.00, 24hr order. It comes with a 1 year warrenty. I know, I know chances are it will last alot longer than that....usually. But I could have gotten a bad one, yep that never happens from a parts store right??? Besides I drive my car ALOT and in a year it will probable get another 24,000 miles put on it.
So I have decided to FINALLY start marking my replacement parts with dates and a hint where I got it from. Will make it easier to match it to paperwork later.
Michael
Michael
