Suspension Tech question - ghetto methods to stiffening up a 944?
#31
M030 springs are stiffer, but do not fit the stock lower perches.
Find a set of 200 or 250 lb/in weltmeister take-offs that have seen a lot of street mileage, maybe will be rusty enough not to draw unwanted attention.
#33
1 Post
Cut the front springs if you want it a bit lower. There is a right way and a wrong way ya know.. Tracked a car for 10 years on cut springs..just do it correctly. Cheap too.
Then just lower the rear eccentric bushing as far as it will go...maybe even grind out the slot a bit more for some extra travel.
Want less sway bar movement? weld it/bracket to the frame, and isolate/remove the rubber bushings. Take out the sway bar endlink bushings..use washers..
Oh and chain the motor down to stop the twisting action of the engine on its soft mounts..put that torque to the wheels instead.
Can you tell I'm an old skool hot rodder?
#34
#35
I have brand new urethane bracket bushings with the 26.8, too. I think I gave $75 or so for the 26.8 I bought previously (go figure.) I'd send it your way for $75 shipped including the bushings.
Pretty sure the team would kill me if I didn't take one of these "free" rear bars. I see offers from Sydney, Pettybird, and Greg.... definitely appreciated. I'm in Chicago, pretty sure none of our team will be at 'fest, so it's down to Sydney and Greg.
Sydney - where are you? (I don't know where "District 12" is)
And do either of you also have the hardware to mount it?
#37
I have the brackets but I think I'm light on the bushings by one...it rolled away in the garage and I can't find the damn thing. Send me $25 to cover shipping for the 25.5, 16 bars and KYB's and they're yours.
#39
The front springs off a Kia Sportage (junkyard $12), will need to be cut down, but will more than double your stock front spring rate.
For the rear, get the beetle coil-overs, and cut the springs (link below)
http://www.ebay.com/itm/VW-Bug-Dune-...sories&vxp=mtr
We also toyed with the idea with rigging up a bump rubber setup from a suburban or something off the top of the rear control arms.
Also, I heard that one of the Volkswagen busses had 28mm rear torsion bars that fit... but I'll be damned if I've been able to find them.
As for shocks, dont worry about that, as long as they're not blown, you're fine. You need springrate!
#42
I read an account by a famous driver that they would weld square bars or angle iron, like 1/4" x-section, onto the length of the sway bars to increase the stiffness. I'm not an engineer, but it seems to make sense. Lemons legal? BTW, I have one pair each of two-dot blue and two-dot yellow springs I could donate.
#43
dont know what ours is going to look like yet I will keep posted on here when we decide.
currently its flat black and anarchy signs on the doors and number 57
#45
Ooof, I thought you guys were kidding about that idea.
Make sure you watch the welds on the ends of the angle iron over time/mileage. They may be prone to cracking, and the bar itself may also be more prone to fatigue failure in the heat affected zone of the welds.
