Wrong idler pulley?
Wrong idler pulley?
I have an 86 951. Recently found the idler pulley bad, so I pulled it out and ordered a new one from ebay. The one I got is half the size of the one I pulled. Is there some common upgrade I don't know about that requires a larger idler pulley? How do I get the right one?
I'd suggest you get the part number from Pelican Parts or AutoAtlanta diagrams and then verify the next one you buy on ebay or wherever. I just bought the entire belt and roller kit since I wasn't too sure of the history of the maintenance of my car.
So then when the new old stock parts arrive and you realize what happened, what do you do? Sell them on ebay. Kinda of uncool but whatever...Bruce
PS... It would be nice if we had some sort of configuration chart to look at.
you got the early water pump idler for the pump without the belt guard. You need an 87+ idler roller -or "updated" pump style. To get the right parts, try ordering from one of our vendors that know these cars like www.rennbay.com or www.paragon-products.com or www.lindseyracing.com
Proprietoristicly Refined
Maybe just read Clarks-Garage.
http://www.clarks-garage.com/shop-manual/cool-07.htm
It sounds like you bought the 32mm idler roller for the regular water pump.
That roller is cheap.
You need the 46mm idler roller that costs more for the turbo "updated" pump with belt guard.
The same goes for the complete "Belt and Roller" kits.
The updated 46mm roller kits cost a lot more.
John
John
