Thicker Headgasket
Old 05-28-2012 | 10:57 PM
1987Porsche944WithRealLongName's Avatar
Default Thicker Headgasket
My pistons stick out a bit from the block face so I need to go with a thicker gasket. The sites I've seen have a 1.4mm gasket listed for the 1989 944 and the S2/968. However it says it "may" fit the later cars as well, so can someone clarify please?
http://www.pelicanparts.com/catalog/..._pg2.htm#item6
It's an 87 n/a block with turbo internals
Old 05-28-2012 | 11:59 PM
MAGK944's Avatar
MAGK944
Cometic HG come in .051" .060" .075" Lindsey Racing carries them, standard and overbore.
I guess I should've mentioned I'm trying to get away from a MLS as the last one leaked
Old 05-29-2012 | 12:58 AM
Also I was getting 0psi in one cylinder and my #2 intake valve is just tapped up a smidge, obviously the cause. This head had a fairly recent rebuild, can I just switch out the valves myself or am I going to be forced into taking it to a shop?
Old 05-29-2012 | 11:37 AM
Van's Avatar
Van
I think the real question is: why is your deck height off?
Old 05-29-2012 | 01:42 PM
V2Rocket's Avatar
V2Rocket
Rainman
how far out do the pistons stick?
Old 05-29-2012 | 03:20 PM
968 GUY's Avatar
968 GUY
Those must be some special "pop-up" pistons, or someone got happy on the mill.
Old 05-29-2012 | 07:03 PM
Reimu's Avatar
Reimu
The motor had a broken belt a long time ago, I figure the PO must've had it milled for whatever reason.
We didn't have a chance to measure how far out they stuck up but it was a solid .5mm or so
So any answers?
Old 05-29-2012 | 07:12 PM
Van's Avatar
Van
Extra thick copper head gasket from Broadfoot.
Old 05-29-2012 | 07:22 PM
Reimu's Avatar
Reimu
That sounds like it'd leak more than the cometic. I searched around and noticed some people have luck with copper spray on them, this last one leaked coolant on one side and oil on the other externally.
Quick Reply: Thicker Headgasket
