Door stay failure.
Old 05-22-2012 | 11:46 PM
Dougs951's Avatar
Dougs951
Default Door stay failure.
OK, may have a new one here, search didn't help.
On my S2 the door stay has ripped through the sheet metal on the door side.
Anyone seen this or have a fix, short of taking the door off and welding it?
Old 05-23-2012 | 12:11 AM
Butters944's Avatar
Butters944
Today I got
My Custom Title
From: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
Oh damn
I'd say you gotta weld or replace the door, or maybe get creative with the door-stay. Like, hard to explain but, attach a piece of metal bigger than the hole to the piece, and slide the piece through the hole from the inside of the door, so it stays..?
Old 05-23-2012 | 12:45 AM
944Ross's Avatar
944Ross
That's easy welding for a body man to do in-place (after removing flammables from inside the area). He can reinforce it, too. Definitely want a permanent, functional fix. If you can cut the stay socket and surrounding metal out of a parts car that would be best.
Old 05-23-2012 | 01:00 AM
LeRox's Avatar
LeRox
I agree that this appears to be the best approach. There is alot of stress happening in this area. Sorry to hear this has happened and a bad door stop can turn a great driving outing into a sad ending. Trust me.... since my driveway is not flat....
Old 05-23-2012 | 03:08 AM
Techno Duck's Avatar
Techno Duck
Look on the 993 forum as broken door straps are a common problem. Might be able to find a body shop nearby that is recommended.
Old 05-23-2012 | 12:37 PM
V2Rocket's Avatar
V2Rocket
Rainman
I've often wondered if that could happen...guess that answers that!
I'd weld something up on both sides of the door edge if you can reach that far. There should be some wiggle room between the door and the body in the jamb, so you might be able to get a 1/16" piece in there. Do that on the inside as well and should be good for life.
Old 05-23-2012 | 01:10 PM
brian944turbo's Avatar
brian944turbo
What color is the car. I can bring a door and swap it at the fest.
Brian
Old 05-23-2012 | 01:37 PM
Ben951S's Avatar
Ben951S
Can I get a pic of this? Trying to visualize!
Old 05-23-2012 | 06:41 PM
Dougs951's Avatar
Dougs951
Brian
I will grab a pic for you,
Brian, It is LY7T Crystal Metalic. I am also looking for a good set of burgundy 10 speaker door cards, maybe we can work something out.
Old 05-23-2012 | 08:40 PM
V2Rocket's Avatar
V2Rocket
Rainman
Originally Posted by robstah
I plan to weld something close to 1/8" thick on the inside of the door, if clearances will allow. Honestly, if I lose 1/8" in door travel, I'll take it. Right now, it flops open and I have to hold on to it to make sure I don't knock other cars/objects/etc. Hill parking is a pain as well.
Any room for a spring of some sort?
Quick Reply: Door stay failure.
