Expansion Valve
I have a 85.5 944 and have made two attempts to get a replacement expansion avle and have recieved tow different types that are bothe different than I have installed in the car. My current expansion valve is the 90 degree brass type with the single temp sensing line attached. The first valve I recieved was the block style. the second is the 90 dregree type, but also has an additional small line coming off of it. I looked the valve up on several different suppliers sites and I am finding different valves all listed for the same car. Was there three different expansion valves used during the transition from the 85/1 to the 85/2. I have run across a few other items that were 85 not 86 on the car. When I replaced the brake pads they were 85 not 86.
Any help would be great as the temps are going up and I need to get the A/C up and running.
You can try the porsche pet to find the part number.
http://www.porsche.com/usa/accessori...artscatalogue/
Also, does this look like the correct one:
http://www.paragon-products.com/AC_E...573.201.00.htm
Give the dealer a call, they will tell you the correct part from your VIN. Sunset Porsche can get you the correct part with full factory warranty and they are cheaper than most. (no affiliation)...
Proprietoristicly Refined
Zims---call to make sure.
This is the style I used on my '87 924S.
http://www.allzim.com/acatalog/Expan...85_91_968.html
John
John
I am not sure that it is bad just anted to be sure as I have to replace the compressor any why the system was open wanted to change any possible part that could be bad. I have not checked the high side pressure yet, but i have not been able to get vent temps below 50.
