The beginning of another mod (S3 3.0L Conversion)
Old 09-30-2012, 10:13 PM
  #31
Dimi 944
Dimi 944's Avatar
Al ready have a new rotor and cap lined up
Originally Posted by odurandina
nice project....
changing out the distributor rotors (at least every 30 k miles) saves on towing.
changing out the cap after 60, 70, 80 k miles is fine.
Old 10-01-2012, 09:09 AM
  #32
will951
will951's Avatar
Great project!
Old 01-20-2013, 11:30 AM
  #33
Dimi 944
Dimi 944's Avatar
Default Update 6
Finally, another update on my conversion! The car has been moved to my partner's garage (Dark Horse Garage LLC) where he and I will be doing the engine and tranny swap. The tranny (AOT) came from '91 S2 and it is being refreshed - the LSD plates were worn out and the lock was out of spec. The engine bottom end was refreshed as well - rod bearings replaced, front and back crack seals replaced, crank scraper installed along with new oil pan gasket and some cosmetic mods along the way. The belts and sprockets were replaced and the cam timing was redone as well. Next will be the cam shaft cover and the torque tube rebuilt.
Once all major components are done the swap will begin and should go much faster. Additionally, I picked up a set of nice wheels wrapped with Hoosiers to match the new power and torque that the car will have.
Old 01-20-2013, 06:19 PM
  #34
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
nice project.
Originally Posted by Dimi 944
Also, I found that the distributor cap is shattered and the valve cover is cracked - surprise!
like we've said a hundred times.... change your rotors often
at least every 30 k miles. they fail and take out the caps.
caps will go over 100 k miles.
Old 02-09-2013, 11:47 PM
  #35
Dimi 944
Dimi 944's Avatar
Default Update 7
The valve cover has been finished and ready to go on the motor. Next, is the torque tube rebuilt.
Old 10-15-2014, 12:15 AM
  #36
Dimi 944
Dimi 944's Avatar
Default The last UPDATE of the build!
Finally, found some time to follow up on this thread and lay out the final results as of 10/14/2014!
The refreshed engine, rebuilt torque tube and refreshed transmission were installed in about 16 hours straight with the goal to have the car ready for a track event....well, it did not work out as planned.
The car was running at 01:30 in the morning on 11/03/2013 but had some overheating issues and I did not take it to the track. It was the wiser choice after all.
Huge thanks to my dear friend Jay from Dark Horse Motorsport who hosted the conversion and did a tremendous amount of specialized and fabrication work to get this project completed.
Some pics and videos of the final stages of the project and its latest status.
The last minutes of the solid 2.5L 8V engine in the car.
Ready for carnage.
The new power plant with custom ceramic coated headers.
It fits!
The new drive train replacement - AOT Transmission from S2
The upgraded S2 LSD transmission.
The latest upgrade - Tarrett Engineering Sway Bars and Koni Coilovers.
It is alive!
Custom straight exhaust from the header back. It was just fabricated and installed. I recommend watching the video on a device with good speakers/headphones.
Old 10-15-2014, 03:26 AM
  #37
rufrob
rufrob's Avatar
Congrats with the swap. BTW,Thanks for the great turbo I bought from you.
https://plus.google.com/u/0/photos/1...96114623474017
I cant get my S2 engine to start after the swap. I swapped the front harness for the coil and igniter as well as the engine harness and ECU. What did you do with the wiring to get it started? Any help would be greatly appreciated.
Quick Reply: The beginning of another mod (S3 3.0L Conversion)
