Front reseal? Balance shaft seal removal?
Hello. First time doing this on my 951... I've got it mostly apart now. I just need to get the seals out and wait for the rest of the new ones to arrive in the next few days. I haven't seen any write up on this for every seal. The seals I'm wondering about are for the balance shafts... before I start prying on stuff. What's the order to removing them? Is it a seal, collar/sleeve, o-ring, thin clear seal? Do I just pry out the front seal then pull the collar out? I just don't want to screw anything up... Thanks
Just pull the front housing and push the seal out from the inside back with a socket. Remember that the upper and lower ones have different seals. They look identical so don't mix them up. Look at the write-up on Clarks Garage.
