name these plugs!!
still diagnosing my no start issue and was getting a spark around my turbo so i ripped it apart, and put on anew j boot, i found this pluglike broke off (ithink it goes to the circl plug next to it) and also this random hose (not the vac hose) coming from the plastic casing in the front of the engine not hooked into anything.... then this plug near the dme not plugged in, what are they and are they needed??
![](http://i16.photobucket.com/albums/b22/strtsol1109/IMAG0233.jpg)
![](http://i16.photobucket.com/albums/b22/strtsol1109/IMAG0202.jpg)
top picture goes to the temp sensor for turbo cooling pump.the sensor fitted on the pipe that crosses the turbo cold side in your pick,seems that the sensor tip has broken off and youll need to replace it.2nd pic,i dont know.hope this helps
found this searching the 944 turbo forums, napa PN#ECH FS158 - its a lower profile,but still works fine
OEM Porsche PN#930-606-118-00 - if you want the OEM sensor
http://www.napaonline.com/Catalog/Ca...158_0217620689
As was mentioned, first picture is the turbo temperature sensor, 930 606 118 00. Lindsey racing has them for $37.
Not sure about the hose. Edit: It's a vent for the timing cover and aparently goes to the airbox. Some people cap this off; when I looked at mine that's what the PO had done. Not sure why the timing needs to be vented, it's not exactly airtight anyway.
The bottom plug is the "codes plug" and is normally unplugged. I believe there's some way to use it for diagnosis of DME issues.
with regards to the belt cover breather hose, i have just removed the hose and fitted a 25mm oil breather filter which cost a mighty £4. porsche deleted this hose on the later models, so i guess not really important but i thought to avoid s--t getting in there i'd better cover it.
