Flywheel Lock
Does anyone have a flywheel lock i can borrow for my upcoming Belt Job? I'll pay for shipping both ways and I am also willing to put a deposit on the lock until you get it back?
I'm located in Southeastern, PA.
Thanks,
Steve
Thanks,
Steve
I didnt think so, but i'm no expert on this timing belt stuff, and for some reason i'm really not excited about doing it. I've done many many timing belts on fwd VW's and Audi's but this one has me less then thrilled about starting it!
PM me your address, cover shipping and I will send it out ASAP... only really need it to remove and retorque the crank bolt!
BTW, mine is for a 944 , not an S2 or 968..
After doing the belt in a 1.8t passat, i must say the 944 is really a lot easier to do. No moving the front core support into maintanace position or anything and no taking the bumper off either :P
Its not that bad.
Its not that bad.
Hi,
the first video shows the job without a special tool, just using a 6mm Allen key. Actually, if you only change the belts, you won't need any lock. The lock is only needed for opening the central bolt.
The second video shows how to make the flywheel lock yourself.
Best regards,
Jürgen
Best regards,
Jürgen
