My 944 project /side skirt?
#61
WTF does that mean?
Seriously. Have you swapped in a motor in a chassis it was never designed for? It creates 100x more work and more potential problems then you will have with a properly built factory motor.
I'm not against engine swaps, I've put several non OEM motors in various chassis. Even when done right you end up with issues and custom one off type parts and wiring. Make it much harder to just roll into a shop and have someone fix it if need be.
The 951 plant is fine at that power level. 95% of the problem people have with them is related to two factors. First, they take an old, improperly maintained motor and start modifying before they catch it up on old hoses, injectors, etc.
Second, they start adding boost with no regaurd to the rest of the system.
Rarely do you hear about issues with the 951 that are not related to just old parts or some guy that was just cranking up boost!
You simply see more built Audis because there are a bazillion more of them and they were cheaper to buy initially.
#62
WTF does that mean?
Anyway, if the solution is to rebuild the motor to make it ready for 400hp, then it's true, it really doesn't matter: Audi or Porsche.
