Battery Kill Switch
I am in the middle of hooking up a street use (not for track) kill switch to my batterys Negative. The switch i am using is a 300 amp switch with 1/4" wide post. Wanted to know what size wire would be best for this application? I am only using the switch for theft/storage and to kill the car when working on it.
i was told 4awg would be fine but it seems to small to me so i was going to go with 2awg.
i am running it from the bat to the glove box so we are only talking a few feet so price of wire does not matter.
any input would help....
http://forums.clubrsx.com/showthread.php?t=787105
this is what i am going to be doing and that is the same switch style that i am using
i dont need a kit or any thing like that
all i wanted to know is what size wire would work and should i use a fuse and if so what size
keep in mind this is for the negative terminal
You don't need a fuse on the ground (negative) side. Have to ask why put it on the ground side? The grounds on our cars can be very temperamental, I consider them a maintenance item. If you do it that way make sure you get a good quality switch that doesn't introduce any resistance there when it is closed.
Personally I would put it in the traditional positive side. Positive kill switches generally have a set auxiliary contacts where you can wire up your alternator exitor wire, radio, alarm, clock and central locking. This ensures those systems will remain functional when the kill switch is open. Otherwise you will always be coding your radio, setting your clock, etc. Just something to think about.
i already have a disconnect on the negative termanal so i really dont mind having my radio and clock reset i just dont want to have to open the hood every time
i already have the switch installed i was just trying to find out a good size for the wire i guess i will just go with 2awg
Lazy... here you are Recommended Wire:
AWG 2/0
Capacity per ABYC Standards: 316 amps.
The wire you select must be large enough to meet both ampacity and voltage drop requirements. These are the wire sizes this circuit needs to meet each requirement:
Ampacity (Additional Derating Factors): Ampacity (ABYC Standards Only): Voltage Drop (ABYC):
No Additional Derating Factors were entered.
AWG 2/0
AWG 3
AWG 2/0
AWG 2/0
AWG 3
Erm, 2/0 ? 2/0 is massive. The stock ground wires are 4 gauge I believe.
A 2 gauge wire should be good. Where is this switch located? Length will play a factor in size.
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
AWG 2/0
AWG 2/0
AWG 3
AWG 2/0
AWG 2/0
AWG 3
the switch is mounted inside the glove box so i will only need about 3 feet or less to get to the battery
