Budgeting Question
#31
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
figure out your tipping point. then, add like, 5,000 dollars to that number (or about 3,000 dollars and a rad set of tools).... then the car can be yours without hurting your feelings or leaving you stranded. cuz that's about what it's going to cost you above and beyond your most optimistic estimates... otherwise, you should fairly consider yourself a risk candidate for 944 ownership enjoying a very light-duty machine.
#32
Howdy fellow Flyer fan.. (Phila assumption
Can we know which "local mechanic" said he can get them in for $50 ?
Are you in Chester County?
Thanks!
PS: In April 2011, we spent $1,700 for an '88 with 225k and using it as a daily driver...
All major mechanicals are less than 3year/10k in use. Fuel lines updated.
We've spent about $850 on updates/maint so far. Good luck!
Thanks!
