Forgive me...making the ride more comfortable...?
I had koni yellows at stock height on stock springs, stock 15" wheels, stock front only sway bar and the ride was stiff and I felt all bumps on my 1984 944. Adjusted the koni's to full soft and it was still a little to jarring for highway driving, it was just annoying.
I had a rear shock spring a leak and while koni was repairing/replacing it I tried Gabriel Ultra from autozone because they are dirt cheap. Now these are not a performance shock by any means but they transformed the 944 into a highway cruiser, think almost land yacht bouncy. There was more body roll but I upgraded to a front turbo sway bar and added a rear sway bar and now the car handles great and does not loosen my fillings on every control joint on the highway.
Front strut cartridge ($35.99) part number G44850, rear shock ($27.99) part number 69616. For a car just pounding away miles on the highway I do not think you can go wrong, especially for the price. And if you don't like it, you're out barely $130 and an afternoon, if you do the work yourself.
Tom
Tom
The ride is a lot easier to enjoy when it doesn't make all that racket back there.
Rainman
Tom
Tom
Got a set of those a few months ago, they for sure made a difference. Now my sunroof seems to be wiggling (I need a new panel seal...really hard to justify blowing $120 on an o-ring though) and who knows what else is loose back there...wish I could ditch the spare tire/tool set without the certainty that I'd immediately blow a tire due to karma.
Today I got
My Custom Title
My Custom Title
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
bigger wheels, but not with low profile tires.
i started with 14" 924 wheels, then moved up to 15" 944 wheels and now i use 17" wheels. smaller wheels will fit in most holes and denivelations, bigger wheels will just "fly over"
i would try some D90 with some 205/55/16 rubber...oh and keep the pressure at maximum 2 bars...i drive my MK3 golf with KW super sport suspension daily and its confortable (1.8bar pressure)
I put KYBs on the rear of mine when I bought it, so I didn't know how bad they were, until I replaced with Koni's last year. The squat under acceleration was bad with the KYBs, but when I removed them I couldn't compress the bastards. I still haven't figured that out, and don't really care to.
I recently had the opportunity to use a shock dyno for a morning and ran a few tests with the various spring rates and dampers I had accumulated.
Don't fit Konis to stock springs, the valving is all wrong. Stick to factory Sachs/Boge and you will be very happy. Most people who fit Konis on less than 250# front springs end up setting them at their lowest setting and that sort of defeats the point.
IMO best "comfort" setting is the factory stock set-up, it was a compromise between a sporty ride and a comfortable ride. Stock wheels, stock tires, stock suspension. If anything play with your sways to control the roll and dial out some of the understeer, but that's about it.
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Spencer will give it a shot for you.Leave strut insert/springs/rear shock & front sway bar as is,since your car is already well sort out with Boge/Sach & all new rubber bushings.Get some 7x16 wheels front 8X16 rear mount some Falken 452 205-55 ZR 16 frt 225-50-ZR 16 rear tires inflated cold front (29psi) rear (32psi),& enjoye your new ride.Btw there is nothing wrong with a quality 16" Fuch repro & it will give your car the rigth look.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Ernie. can't get tires for 16" wheels anymore.
but, make the move to 18s and you have a trillion bargain tire options opening up.
click these links here and have your mind blown.
http://www.ebay.com/itm/ONE-MICHELIN...item1e67672ff1
http://www.ebay.com/itm/Two-Used-Mic...item1c2344e44b
the only issue with ride quality arises when you run a 30 aspect ratio.
