Oil Pump Leak? Upper Balance Shaft?
Meant to post this here and not on the turbo board..
Got a pretty bad leak, it's more like a constant oozing of oil that comes into view on the pump and dribbles down around the crank gear and onto the ground. I can't get a good view of the source while it's running because of all the whirring bits in my face but I took off the tensioner to get a better view. As you can see it puddles a bit on top of the pump there..
The path leading from the balance shaft seems pretty clean but it's hard to tell when everything has a thin layer of oil on it.
