oil question
Old 01-04-2012, 10:42 PM
strtsol1109
strtsol1109's Avatar
haha and i figured allan was joking, ive had hondas my whole life and ive done everything to them fron biult motor, to boosting, to tuning, so i know my way around a car just didnt realize everything was so specific for these cars so i wanna make sure i dont **** something up since repairs seems to be 10x's of the honda seeing as how i coulda bought a whole motor for 400 if i blew mine... lol o well i love the porsche
Old 01-04-2012, 11:39 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
what i don't like about conventional oil is not only centered about what i've read... from what i've read, the rotella stuff is good and can take a decent beating, but it's all basically crap.... the thin part that actually allows conventional oil to flow, goes away real quick, leaving the thick part behind. then that part gets even thicker and finally turns to sludge. it leaves a little bit more of this sludge behind after each oil change.... if i ran it in my car my engine would be all but dead by now.
Old 01-04-2012, 11:43 PM
ernie9468
ernie9468's Avatar
Talking
Originally Posted by strtsol1109
forgot to mention all that, its a 86.5+ 944 turbo, im in wv so its cold and snowy, also it has currently the valvoline vr1 20/50 but thats too much weight for these cold starts.. will the rotella 10-40 HD stuff they sell at sams work or should i look into more of a mobil1 synthetic 10-40
You should be good with 10W40 Synthetic,something else you should be aware off,if the trans/diff oil has been in there for a while I would seriously consider dumping it & put some fresh one in there before winter set in for good.Here again you will go with a full synthetic oil 75w90, choice of oil will be yours, most popular with 944s owner are Mobil/RedLine/Swepco just to name a few.Both trans & diff use the same oil on our car .For more maintenance infos use www.clarks-garage.com once on the site enter (Garage Shop Manual ) & scroll down to what ever maintenance you want to do.
Old 01-04-2012, 11:53 PM
strtsol1109
ok for doing the trans/diff oil is there just a single drain bolt, again im used to fwd didnt know if there was one on the tranny n axle houseing or just one to drain the whole system... i dont know how long its been in there so might as well change it
Old 01-05-2012, 12:43 AM
ernie9468
ernie9468's Avatar
Talking
You got two plugs one upper # 22 in the diagram & one lower # 2,you want to make sure you remove the upper plug first (this will be the refill plug ) if a hoist is available it will be butter in the pan & should be done in 15 minutes worth paying a shop beleive me .Make sure you spray both plug with W-40 & let them soak before you try to remove,also you will need the rigth tool for removing the plugs will send you the size & a pic later on.
Old 01-05-2012, 12:45 AM
Fara
Fara's Avatar
The Allen head to remove the drain bolt is a 17mm.
Just FYI.
Old 01-05-2012, 12:49 AM
strtsol1109
i have allen head sockets so i should be good, i have my speed sensor to replace to try n get my speedo to work too, im assuming thats #18 correct?
also what book are u getting these pics from?
Old 01-05-2012, 12:53 AM
ernie9468
ernie9468's Avatar
+1 17mm
Old 01-05-2012, 01:04 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
Don't see a problem with conventional oil. I run pennzoil 10w40 year round
Old 01-05-2012, 01:10 AM
ernie9468
ernie9468's Avatar
Cool
You got a PM (private message)
Old 01-05-2012, 01:27 AM
strtsol1109
i dont really wanna go from syn to conventional, than back to syn in the summer... my boosted honda hated that im sur eth eporsche would like it less
Old 01-05-2012, 03:14 AM
odurandina
Team Owner
odurandina's Avatar
if you pick a season to run conventional oil...... let it be the summer.
winter ? hell no. good winter oil choices; synthetic 0w40, 5w40, 10w40, 0w50, 5w50.
Old 01-05-2012, 12:08 PM
strtsol1109
just ordered some redline 75-90 for the tranny and royal purple 10w-40 for the oil, and a clock led rebiuld kit...lol maybe my tranny will shift a bit smoother with the fluid flush
Old 01-05-2012, 01:06 PM
ernie9468
ernie9468's Avatar
Talking
Don't know about that Royal Purple __Mobil /Valvoline VR 1 or Brad Pen but R P not for me.It will take a while before you feel the difference shifting your tranny usually at least a couple of hundred miles.
Old 01-05-2012, 01:37 PM
strtsol1109
rp was the only 10/40 i could find locally, my car was cranking slower then usual so i wanted to get lower viscositiy oil to try n help it out since it does that pumping oil before itll start
Quick Reply: oil question
