Anyone have a parts washer?
Those parts look great!
That solvent looks good too - I don't think mineral spirits (which I'm pretty sure is what we used when I worked at a lawn mower shop when I was in high school) can make the "Flammability - 0" claim that yours can. I know that whatever I get needs to be safe since it'll be sitting in my attached garage. With a health rating of 1, I don't have to be too worried around my 3 year-old either.
I diluted it about 1:3 gallons with water.
I bought a portable dishwasher off of CL.
I hook it directly to the drain on the water heater, and use either Simple Green for "light cleaning", or solvent/glycerine soap for heavier duty stuff.
Run your parts through a "pots and pans" cycle, and they come out spotless
I have one from harbor freight and the pump never worked, so I have been using it for soaking, scrubbing and dipping. Just getting around to shopping for a pump. $80-110 at Mcmaster-carr or grainger
http://www.lowes.com/pd_124762-68-63...ductId=3010340
Try some of this stuff... Mix about 1/4 carton in 5 gal of water and it works great. Tri-Sodium Phosphate FTW... and its cheap.
My problem at the moment is I need to clean a 200-lb cast iron block and a 90-lb crankshaft. I'm thinking 55-gallon drum.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
We just finished cleaning out our parts washer after the pump quit working. Intake screen inside the metal housing was clogged, so we opened the metal housing and cleaned that out and were rolling again. We are thinking of mounting a remote oil filter housing and filter to the side of the washer, then once the fluid starts to get dirty, skim the fluid from the top down, running it through the filter and a pump and back into the washer once the sludge is scooped out of the bottom. Toss the cheap filter each time and we should get multiple rotations out of the fluid. Fluid isn't cheap when you are washing a lot of drity parts, lol.
Most good old-fashioned (pre HF) washers have a sludge trap in the sump, just like sewage treatment plants. But what do you do with the sludge once you scoop it out? It shouldn't go to a landfill.
Of course not, it gets dumped in the oil recycling bin and taken to the recyclers, LOL.
