Anyone in here with access to the RX7 forum, or with an RX7 oil cooler FS?
12-12-2011, 10:11 PM
RainmanRennlist Member
Easiest way would be to get the 944 turbo/S2/968 oil filter mount...
Or you could make a plate to bolt onto the block and tap holes in it for oil in/out and remote oil filter...
12-12-2011, 10:28 PM
951 mount bolts in place of the Antichrist, then you use hoses to attach the cooler? Cool.
12-12-2011, 11:01 PM
yes, but the possibility of oil/coolant leak is still possible, but oddly much less common (at least around here)
12-13-2011, 12:21 AM
You can use the turbo block off plate. Then maybe some adapters to match the lines you'd use.
