944 nose bearing alignment
I'm rebuilding a 1989 944 and am having difficulty aligning the front one-piece main crankshaft bearing with the crankcase alignment pin.
The bearing fits snuggly enough into the crankcase seat so that, while lowering the crankshaft, I can't move the bearing to feel it engage the pin.
I thought I had it seated properly on my first reseating attempt but, after noting that the crankshaft was not rotating freely enough, found I was off slightly and the pin bit into the edge of the mating hole in the bearing. This deformed the bearing which pressed on the crank which resulted in tough-turning. Nuts. Have a new $250 set of bearings and don't want to ruin another set.
Any suggestions on how to align the bearing to the pin during reseating of the crankshaft?
Thanks!
wrong posting location - sorry, newbie mistake. rewrote post and placed in 944 forum
Thanks!
Last edited by dmarks; 12-04-2011 at 12:54 AM. Reason: wrong location - sorry, newbie mistake
