I hate it when it rains
GenTite Black EPDM Rubber RoofingGenTite EPDM roofing is a high-quality rubber roofing that is resistant to tears, impacts, punctures,....its not cheap but ill get a roll or grab some pieces from friends that use it..pieces theyd throw out would be more then we'd need to do ..one piece maybe 20...
but i guess if rusted the gel or rubber roofing is a much better idea that welding metal i mean its 2011?
how hard is it to put a turbo in a 83 944....2k more?
Today I got
My Custom Title
My Custom Title
Professional Hoon
Alot more then that. you need a turbo to start with, turbo mount/oil drain, custom exhaust, change your dme, chip set, custom oil lines, custom water lines, turbo water pump and more. it's a big list. search it here, it's been covered before.
no...there is a drainage tube made of rubber. You dont need to replace it. It runs down from the sunroof and drains out from under you battery. It connects to a metal 'nipple" under the a-pillar. It's a pretty common problem...just re-attach it so it drains all the way through.
