Odd electrical problem
Old Oct 21, 2011 | 07:10 PM
PeteL's Avatar
PeteL
Got Nothin'
Default Odd electrical problem
Today, after the car sat in the Parkin lot for a few hours, the power windows and the fresh air blower did not work. After a short drive, they worked, but then stopped working again. All other electrics work: lights, radio etc, just not windows and fresh air blower.
Fuses are good.
Old Oct 21, 2011 | 07:14 PM
Rich Sandor's Avatar
Rich Sandor
Wiggle the key and see if that makes a difference. On my 968 I had the same symptoms. It turns out the the spring inside the ignition did not pop the key back far enough after I started the car, and kept the blower and windows and headlights off until I manually moved the key back just a hair. (When you start the car, the ignition interrupts the windows, blower, and headlights, because they are the greatest draw on the battery, which needs 100% of it's power to crank the starter.)
Old Oct 21, 2011 | 07:19 PM
PeteL's Avatar
PeteL
Got Nothin'
That makes sense. But just tried, and nothing changed. But ignition switch is original.
Is there a relay or something that i can check?
Old Oct 21, 2011 | 07:37 PM
PeteL's Avatar
PeteL
Got Nothin'
What other testing can I do?
Old Oct 21, 2011 | 07:49 PM
Rich Sandor
The only things I can think of, if it's not the ignition switch, is the ignition relay (which I don't know how to test other than borrowing another one) or there may be a loose or inadequate ground. There is a small possibility you may have a short that hasn't blown a fuse yet. You'd really have to stick your head under there and look at the harness and check the ground points near the fusebox, check all the relevant relays and connectors for the relevant wiring.
Old Oct 21, 2011 | 08:28 PM
Butters944's Avatar
Butters944
Today I got
My Custom Title
From: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
My first guess is ignition switch as well. If your car is early, it's an easy and cheap replace.
Old Oct 21, 2011 | 11:25 PM
PeteL's Avatar
PeteL
Got Nothin'
The ignition relay is the same as the sunroof relay. I swapped them, no change. So there is something telling the windows and the blower not to work.
Old Oct 22, 2011 | 01:53 PM
PeteL's Avatar
PeteL
Got Nothin'
My headlights work, but not Windows and blower. Could it still be the ignition switch?
Old Oct 22, 2011 | 02:38 PM
Butters944's Avatar
Butters944
Today I got
My Custom Title
Ignition switches can do plenty of strang things- when mine was bad, the windshields wipers randomly went on, and the radio would turn on and off- if you find that the things stop working when making a turn or going over a bump, and randomly do and do not work, it's probably ignition switch. Easiest thing you can do is take the ig. switch out and look at it, it takes 5 minutes to get it out and when you do it would obviously have cracks in the plastic. (I'm talking about an early car, somebody correct me if there is difference between generations)
Old Oct 22, 2011 | 06:57 PM
PeteL's Avatar
PeteL
Got Nothin'
Yeah. I am fairly certain it's the switch.
Old Oct 22, 2011 | 07:41 PM
75ohm's Avatar
75ohm
Resistance is Futile
If you take it out and it has the same message as the oil pan, then you know for sure...
75ohm's Avatar
75ohm
You have copies of the shop manuals to trace the schematic out?
Old Oct 22, 2011 | 09:15 PM
SeaCay's Avatar
SeaCay
Thefu
If not let me know, I have the full set if/when you need 'em.
Old Oct 22, 2011 | 09:30 PM
PeteL's Avatar
PeteL
Got Nothin'
My plan is to pull the ignition switch, and see if it is bad. Sure sounds like it is.
Old Oct 22, 2011 | 09:31 PM
75ohm's Avatar
75ohm
Agreed man
