225/60/16 GOODYEAR EAGLE RS-A
Four of these tires for only $100? It was a deal so I bought these tires that are a little bigger than stock, for my 86 turbo.
All four are 225/60/16 GOODYEAR EAGLE RS-A. Does anyone know anything at all about these?
Compared to stock:
Sidewall height is 0.87 inches larger on these tires. The fronts will be .79 inches wider. The circumference is 5.5 inches larger than the fronts so if my speedometer says 65mph I'm actually going 69.58. (The speedometer cable is hooked up to the front?)
http://www.discounttire.com/dtcs/infoTireMath.dos
Compared to stock:
On any of the late cars (turbo's included) the speedo is electronic and run off of a sensor on the trasaxle... the early cars have the cable-drive speedo hooked up to the front.
I have the correct size tires on mine and your speedo is closer to your true speed than mine lol These cars are notorious for having wildly inaccurate speedo's, so your doing well to be that close
peace
Cyberpunky
peace
Cyberpunky
Former Vendor
Goodyear Eagle RSA's are the usual OEM tire on Crown Vic Police Packages. I've had a few sets on my "company cars" over the years and have found them to be a good all around performance tire with all weather capability. That was a good deal you got on those. Looks like they are still on Ford Police steelies.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
the speedo's innacuracy will go as high as 12 mph running your small tires.
set your speedo back about 4 mph and move up to 25 and a half inch tires.
gps will confirm an accurate speedo at 130 mph (if you don't mind your cars not making it to the redline).
These things got bad reviews on tirerack, so thanks for the comments guys. no way i would want to put bad tires on my 944.
I am really thinking about selling those police tires/wheels and getting some appropriately-sized, new tires that have a good reputation.
http://www.tirerack.com/tires/tires....o&autoModClar=
These are rated very highly for a good price. Thoughts? Any comments or suggestions? Thanks for the help.
The RS-A would be aggravating if you do any spirited driving, IMHO they are an all-season not worthy of the Eagle name. The Direzza Star spec is a great tire worthy of track duty.
BTW, if the first 2 digits of the serial on those RS-A tires is 4B then they are made in the tire plant I work at. If they are indeed police car tires then they are also somewhat different from regular RS-A construction.
