rear parking light not working
Any thoughts, notice that my right rear parking light wasn't working. Replaced the bulb, brake light seems ok, no parker.
1990 944 S2 Cab
1989 944 2.7
1990 944 S2 Cab
1989 944 2.7
i would remove the lighting assembly. there are two plastic nuts that you unscrew and the assembly slides out of the body. clean the connector going to the assembly and clean the socket assembly. i found a lot of corrosion on my connectors and after cleaning them and the sockets and installing new bulbs, everything was back to normal.
