Rubber Clutch
Rubber Clutch
I recently pulled the motor out of the 85 I picked up recently as a bearing had seized.
Took the clutch off the old motor with every intention of putting a new disc on the new motor.
The rubber clutch seems to be in great condition though. There are absolutely no cracks in the rubber and it looks great.
As always the less money spent the better but would it be eternally stupid to reuse this clutch with the new motor.
I Wouldn't and Couldn't recommend re-using it..; unless of course you love removing the engine, or dropping the tranny...
Before I replaced mine, the Car was shifting Really Bad for some reason,,...
Just update it. The clutch is already out and the motor is pulled. Its definitely worth replacing with fresh new parts so you don't have to pull the motor and do the work again. "do it once, do it right, don't do it again."
Agree at 100% get a spring centered one,check those guys www.vertexauto.com they sell one of the best spring centered disc around.
Just in case you still have any doubt,yes replace it.
I have one hanging on my wall, it's in great condition as well, and I wouldn't even let someone I didn't like use it.
michael
michael
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Hi gricec, If you plan on junking the rubber centered clutch, I'd like to get it from you. I have an 83 944 with an autotrans and can use it on. I bought the car with #2 rod through the block so have to R&R the engine anyway. Much easier for us to take it out the top. Please send a PM on shipping cost.
Cheers,
Larry
Cheers,
Larry
All together now... in your best Mr. T voice... "I pity the fool who'd reuse a rubber-center clutch."
Replace it with a spring-center one, and you likely won't have to change it for as long as you own the car.
