FS Manual sunroof latches, 944 injectors, wiper plug
Rainman
As title states, set of 4 fuel injectors for early 944 (but will work on any year NA). Injectors work fine, and I will run them through my parts washer tomorrow. $35 shipped for the set.
Also have a rear window wiper plug for sale. Rubber gaskets are in good shape. Remove that heavy, troublesome rear window wiper and plug it to save weight and gain visibility. SOLD
Also have a pair of manual sunroof latches for sale. Get rid of the pesky, never-working power-sunroof system and bolt these on to any 924/944/968. Removal of the sunroof system will save around 10lbs total. SOLD
1 Post
Wait, I thought I had read that the early injectors couldnt be used on a late car due to the different ECU - the impedance was wrong and you risk damage to the DME.
Sorry to thread hijack...
Rainman
No, early and late NA injectors are the same impedance (~2.4ohm) and are almost identical. They can be swapped back and forth without issue.
951 injectors have a weird impedance of around 5.5 ohm.
injectors
