944 S2 Speed Sensor Question
My crack reference sensor plug has crumbled a part, and when removing it I noticed my car doesn't have a speed sensor. Should the opening in the bell housing have a plug of some type? Also, where is the speed sensor on these cars. Thanks for the help.
IIRC on an S2 (16V motors) the sensor on the bell housing is the speed sensor, the reference sensor (hall sender) is in the distributor housing for the cam timing.. but I could be wrong!
And yes there are 2 sensors...
Not Special
I believe you are correct. One in the bell housing and the hall sender at the cam.
No. One sensor in the bell housing for speed and ref. There is a 'missing tooth' on the notched speed gear that the 16V dme's pick off as reference pulse.
In this post of mine is a scope trace I made of what comes off the speed/ref sensor:
https://rennlist.com/forums/924-931-...p-xposted.html
NiceSharky (07-03-2019)
