No spark at #1 and #4
i would check the cap and make sure none of the contacts are damaged on the inside. it's happened in the past but its very unlikely. however, we need more details on the year of your car and the model. 924, 944 or 968?
Ok, new dist cap checked out factory nice. This is a 944 Turbo S bone stock. Was running fine as I pulled away from the garage then less than 1/4 mile into my drive to the store it started missing. Brought it back home and started the hunt. No spark at #1 and #4 so it's running on #2 and #3 and you know what it sounds like...
Could it be DME, DME relay, ref sensor? I'm baffled!
