broken clutch pedal spring
I am looking at buying a '91 S2 and when going over the car with a fine toothed comb I found that the clutch pedal spring is broken. the pedal feels super stiff and catches very early in the throw.
what are your thoughts on it?
could it mean a bigger problem?
broken cluth pedal spring
I just bought a 91 944S2 cab and ithas the same symptom...cluth goes to the floorboard and stays there. I have to manually pull it back. I have to repair it and asume it it is the spring. Let me know if you get it replaced, I'd like to know how. Attachment 548999
If you are talking about the big spring in front of the clutch it is for assistance on depressing the clutch, not to help return it. The clutch pedal sticking to the floor may be air in the lines.
Your problem is the pedal going to the floor and not returning. The most common cause is that you have a fluid leak and air in the clutch system.
Thanks MAGK944.
My pedal does not go to the floor. in fact its hard as hell to even push it half way. I will check adjustment and look for a new spring. every thing else looks very solid on the car so I may be a new owner of an s2
If replacing the spring and adjusting correctly doesn't work I would be concerned that there isn't an issue with the actual clutch...$$$'s
yeah Magk Im a big fan of Clarks Garage. I currently have a 88 na that I feel like Ive built from the tires up. I just didnt know how much effect the spring would have or if there is a much bigger problem. I went ahead and bought the S2 and figure all the money i would throw at the '88 I could throw at a near perfect 91 S2. ill post pics this week.
thanks for your help
