Thank you. Now visually I think there's no physical damage, but is there a way to test it, and yes, '84 model.
If you haven't visited this place do,they got tons of infos about your car www.clarks-garage.com (Click on Garage shop manual) are your fans coming one as they should? Just make sure that the connection on the sensor is clean & is making good contact.
Thank you, I knew the blue connector was my DME temp sensor, and Clarks has a testing precedure to that, but thanks for all you responses. It was just hard to search or look up info on a small wire on the engine block that has no distinct look, but i'm glad everyone on here are geniuses.
