944S 16V head torque sequence
I was reading on clarks garage and it mentions that the torque sequence for the 16V head is different from the 8V motor, but it doesn't say what is different. It only displays the 8V sequence. Does anyone know the sequence for the 16V head so I can install the new headgasket?
Thanks Rennlist!
Thanks Rennlist!
IIRC - you work inside to outside in three steps. 20ft/lbs, then 90 degrees, then 90 more degrees. You can double check your torques after letting it sit 4 or 5 hours. They should all be pretty close. And don't use pencil to scribe any angle marks. Use a sharpie. Pencils and aluminum is a no no.
