power steering bracket broke
I was driving my 944 to work today when the power steering went out. It was hard to tell that anything was wrong until I turned from a stop. I looked under the car expecting a broken belt or a ruptured hose. I found the bracket that holds the power steering pump broken. It looks like it is part of the motor, and not easily changeable. I am not sure how much of a pain in the butt this is.
I found a friend who has a spare manual rack. He recommends using the manual rack. I feel a little extra power with the pump unhooked, but really hate the steering on hard corners, and in parking lots. A real manual rack, or bypassing the fluid through the pump would probably help a lot.
The question is whether to repair the bracket, or convert to manual steering either with the correct rack, or bypassing the pump. I use my 944 as a street car for shared daily driving duty, a fair amount of twisty mountain driving, and some auto-x.
Any opinions are welcome.
Get a used bracket on ebay. I had manual steering and unless your pumped up, it's a pain at the track. Unlike a 911, 50% of your car's weight is over the front wheels. I converted my car to power steering and am never going back. Good Luck.
I wouldn't get that bracket welded. They are so common they should be cheap to buy a replacement used one, plus there's no guarantee the welded part will be straight and hold the PS pump straight.
I have driven a 944 with manual steering, power steering, and PS with the belt removed. I can't see myself ever giving up PS, even though I am sick of the mess, extra parts, etc.
I am staying with power steering. I will be replacing the balance shaft cover. It will be two weekends before I have help for this job. The last of my parts finally came in today.
i think this has to to do with the bolt being lose, i lost power steering a while back and just cut the belt. i knew that the bolt was lose and i think the pump vibrating around caused a crack that ended up braking off. thats just my theory .
A am off today, and the rest of this week, so I started the repair today. I tore apart the front of the motor per the instructions on Clark's Garage. I got to where the water pump and balance shaft cover are off. It took me from 8:00am until 2:30pm. I am a little tired and beat up, but celebrating a victory. Tomorrow it will hopefully go back together with all the new parts.
![](http://i299.photobucket.com/albums/mm301/Stogie25/IMAG0135.jpg)
![](http://i299.photobucket.com/albums/mm301/Stogie25/IMAG0136.jpg)
![](http://i299.photobucket.com/albums/mm301/Stogie25/IMAG0137.jpg)
![](http://i299.photobucket.com/albums/mm301/Stogie25/IMAG0138.jpg)
![](http://i299.photobucket.com/albums/mm301/Stogie25/IMAG0139.jpg)
Today it went back together. This was my first timing belt job. It was a very very long day in the garage. I still have a small power steering fluid (ATF) leak at the banjo bolt at the pump. I will play with it tomorrow. I will also reburp the cooling system. Now it is time to have a victory beer and cigar.
There was evidence of a pretty good impact on my steering pump. The moral of this story is to avoid car washes with rails in a lowered Porsche.
I have to say that it is nice to have a small leak in the steering as opposed to the last month of broken steering.
Thanks Cole for the drop in, and help tensioning the new belts correctly.
