Brake squeak at low speeds
Old 05-27-2011 | 04:57 PM
mhr's Avatar
mhr
Default Brake squeak at low speeds
On my 91 S2 cab when city driving at low speeds usually after the car is warmed up my brakes will squeak even if they are not pressed. I have to be at a crawl, say in traffic or in a parking lot any decent speed and it stops.
I am going to change my brake lines soon and wondering if there is something I should be doing to fix this problem at the same time. Caliper maintenance or adjustment or something?
Mark
Old 05-27-2011 | 05:19 PM
krystar's Avatar
krystar
take out the pad, put brake grease on the backing where it touches the caliper.
Old 05-27-2011 | 11:11 PM
plumbum's Avatar
plumbum
+1 clean up all the contact surface and put proper brake anti squeel on the backing part of the pads. Also changing the pads to a different compund may help
Quick Reply: Brake squeak at low speeds
