idle adjustment/ high idle
anyone know where i can get a rebuild kit for the t/b?
will that kit work even though it states that it fits the 85.5? mine is an early 85.
I doubt it, but I just figured I'd mention it...
I had a similar problem, high idle, no vacuum leaks (after I fixed them), played with the idle adjustment, all to no avail.
I found the culprit accidentally. The cruise control cable was adjusted too tight and not letting the pedal return completely.
Like I said, I doubt it, and that was an '86 so I don't even know if it's applicable, but I thought I'd throw it out...
Good luck.
Good luck.
There were extra o-rings in the kit after I was done rebuilding mine, so the kit must cover some variations...
