Stainless Steel brake lines - Any interest?
I'm picking up stainless steel brake lines for my 86 951. If there are enough folks interested the vendor will sell the lines for $75/set. These are fully DOT compliant lines (meet all standards) and have the benefit of having a swivel fitting at the caliper end (typically this is a crimped fitting and will not rotate on its own) making it much easier to connect and disconnect the caliper.
Lines are available in the following colors: Clear, black, blue, red, smoke green and yellow.
These are similar (if not identical) to those typically selling for $100/set of 4. I need 10 orders minimum to get the discount.
Any others interested?
