opr valve
Hello all
It seems like I have a leak coming from the opr relief valve.
I checked the usual culprit the oil pressure sensor (maybe)
it is so hard to pinpoint where the oil is coming from as you all know
anyway can an opr leak?
you can buy an ultraviolet dye for your oil. I'm pretty sure Autozone carries it. Just dump it in the fill tube, and drive the car for a bit (maybe a day of normal commute?) and then take a black light and shine it anywhere you think it might be leaking... it will be obvious when you find it.
