Uhhh... what do I do now?
So I just finished putting my rebuilt cylinder head on (thank you roman944) and I was trying to put the new heater hoses on and I didn't realize how easily bendable the tubes on the firewall are and I accidentally bent the F@$% out of one. So what do I do now? Can it be replaced easily? Or should I try and bend it back?
Use a pair of needle nose pliers insert them shut and then spread the hole. Heater core tubing is a little soft. You should be able to get it round enough to not leak.
