cam shaft collar and bolt
some how my cam shaft bolt came loose and the rotor and all that was knocking around >.<
soo i need a new cam shaft collar and the cam bolt >.<
hoping maybe one of you guys have one or know where i could get one for a reasonable price thank you
Proprietoristicly Refined
The bolt is availble on Pelican.
http://www.pelicanparts.com/cgi-bin/...C%20Each%20%20
The procedure:
http://www.benms.com/944camseals.html
The reality......
You may find the shaft key has damaged the camshaft when the bolt came loose--common.
Replacement of the camshaft may be necessary if the keyway is bad.
GL
John
The procedure:
The reality......
GL
John
The procedure:
The reality......
GL
John
The procedure:
The reality......
GL
John
I have the collar and a good bolt from my 86, how soon do you need it? (i've got to get out to my storage unit to pick it up)
IIRC it is a TTY one time use item... I know of at least one local owner who has had the bolt re-used, shear, and take out the head!
