'85 944 tire options
I have Fuchs 15" x 7" front and 8" rears.
Looking for some tire recommendations?
So far I found
BF goodwrech, T/A radial in 205/60/15 and 225/60/15 for the rears
Or should I stay with the stock size 215/60/15? This doesn't makes sence to me that the tires are the same size but the rims are 1" wider in the back?
What have you guys used?
So far I found
I went a bit wider in the rear , and used the Kumho ecsta model , all season , good grip and tread wear . I also have the 15" Fuchs . Good luck and let us know what you choose .
AFAIK, the OEM tire sizes were originally staggered, to follow the rims. 215's all the way around is probably someone's choosing.
I have 3 944's, and am running square sizes on all of them. My 85 street car is on 7x15 Phonedials with 225/50's. My 89 S2 street is on 9x16's with 245/50's. And my 84 racer is on 15x8's with 225/50 Hoosiers. IMHO, the fronts are narrower from the factory to induce some understeer. I think the car actually handles better with 4 tires of same size. Of course, turbo 951's may have a different need for more rubber out back.
I would consider 225's all the way around; I'm pretty sure they'll fit fine. Another nice feature of a square setup is that you can rotate the tires periodically; more effective than doing a L to R swap on 2 different sizes.
Just my 2 cents......
Rainman
BFG g-Force/sport, id go 215/60 in front and 225/60 in the rear, although those are a bit bigger.
i currently run 225 all around, 50 in the front though/60 rear and it sticks nicely but i will be going back to a 215/60 for ground clearance purposes (sitting at about 3.5" presently)
215mm = 8.4"
Technically, a 215 isn't undersized on an 8" rim.. but a 225 will also fit.. and so can a 245 also fit on an 8" rim.
One impact a staggered tire size can have is to reduce oversteer. Contrastingly, it can increase understeer
For a "regular" use car, a 215 or 225 would be fine on all 4 corners. Note a 225/60 will have a slight impact on speedo reading since its a slightly taller tire. Your speedo would read "low" vs actual speed.
