1/4 mile in 951
And the results
First run at 15lbs, bogged launch 14.8@109
Second run at 15lbs, spinning, 13.6@108
Third run at 15lbs, spinning, 13.7@108
Fourth run at 19lbs, clutch would not hold, let off, 18.2@58
Fifth run at 17lbs, clutch would not hold 15.3@70
I ran 315 drag radials on my forgelines to get a good time and a hard launch but unfortunately our axles dont like it. I had a k27/6 with the old school guru-link speed density system when I ran the 12.3. I've never been back since the header crossover pipe fmic and true t3 60-1 hifi upgrade.
Rainman
i think if i got into dragging id swap in my spare trans after welding the diff, bring a few sets of spare axles..
maybe an alternative to trying to over-do the launch would be to do a gentler launch but incorporate a nitrous system to make up for the lost start speed...![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
or sneak a 5th injector into the exhaust before the turbo
