help please
help please
Hello my name is Peter and I broke my neddle sleeve bearing in the rear on the tranny.I called Pelican parts and order part number 008-311-123-oem and showed up today.But its the wrong part.I have a turbo car and I guess the bearing is made for a N.A 944.
So I need help with that part number,its going to be out of a S2 or a turbo for the outer race is bigger.It's going to be a Skf bearing.
Peter
Peter
He's looking for the needle bearing that fits in the "middle" case, (counting the main section, center and rear cap as individual pieces) that the main/input shaft goes through.
Pelican has it listed as 088-311-123-OEM, as the rear case needle bearing, and then shows it as superceded to 999-201-476-00-OEM listing as a FRONT case bearing, which is smaller, and incorrect.
What I think he needs is this:
Part #4: http://www.944online.com/cgi-bin/ASI...key_1105739880
