Cold engine hesitation
My 944 NA has a intermittent hesitation when cold at mid throttle. I've replaced AFM with refurbished and no real change. It runs well other than this and when its warm its fine.
Any ideas?
Any ideas?
How cold is "cold?" Here in the Northeast, I get a similar hesitation and "chugging" (for lack of better words), until it is warmed up, usually around 1-2 minutes. Go easy on the gas and turn the heat off until it is warmed up. Try thinner oil in the winter months which helped mine.
Sounds like mine. Has been the same for the past 20 years that I have owned this vehicle. I wouldn't worry about it in cold weather. If it is still the same in the summer, then it could be leaking injectors, a bad coolant (DME) temp sensor, or worst case, a leaking head gasket allowing coolant to seep into the cylinders and cause rough running until it burns off.
Check the DME temperture sensor:
http://www.clarks-garage.com/pdf-manual/elect-19.pdf
