Clutch Pedal is sticking on floor
8th Gear
Hi, my 944 S clutch seems to be working fine when engaged. The pedal has smooth operation but wants to stick near the stop on the floor. It does release but not like it should. I've checked for clearance on the linkage and lubed everything. I see no leaks in the boot and am missing no fluid. The car sat for quite some time prior to my purchase and it looks like the slave cylinder was recently replaced. Any help would be appreciated. Thanks, John
Unbannable
I wonder if the master cylinder has issues. I'm not an expert on this one but the only time I ever had a problem with my clutch pedal sticking when when I was bleeding it and I pushed it all the way down. If the slave looks good then maybe the master is on its way out...?
BB.
BB.
8th Gear
Thanks for all the feedback. We bled the system and found that there was a tremendous amount of air in it. We actually had to pinch the line to the master several times to get it to fill properly with fluid. Once that was done it is now working again. It also appears that the pressure plate may be weak as well so I may have to change the clutch setup.
